We bought some Seal and Go recently for our conservatory tiles which are red and black Victorian. We were a bit anxious as we've not had much luck with previous products. I can't tell you how pleased we are with it. It's absolutely wonderful.
The finish is a beautiful soft sheen, as promised and it looks lovely. Spill water on it and it just wipes off and doesn't mark, like the other finishes we've tried. I gave it four coats using a small piece of lint free cloth and even then I only used half the bottle. We couldn't be more pleased. Alan and Sue Stroud.
A specially formulated water-based blend of acrylic polymers that provides both a stain resistant surface seal and a durable low-sheen finish eliminating conventional two-step methods. May also be used as a pre-grouting sealer. Allows moisture vapor transmission and is not affected by ultra-violet light.
Use on internal unsealed, porous surfaces such as slate, textured quarry, saltillo, sandstone, Victorian Tile, terra cotta, cement pavers and masonry.
1.) Read entire label before using. 2.) For new installations sealer can be applied as soon as 48 hours after grouting. 3.) Surface must be clean, dry, and free of existing sealers or coatings. 4.) Apply using a sponge or paint pad applicator. Avoid puddling. 5.) If two or more coats are applied, allow a minimum of 30 minutes drying time between coats. 6.) 2 hours after final coat conduct a test to determine if surface is completely sealed by applying water droplets to the surface. If water is absorbed, apply an additional coat. Wait 2 hours and repeat the test. 7.) Ready for surface traffic 6 hours after final coat. Keep area dry for at least 6 hours. Achieves a full cure in 24 hours. 8.) Clean applicator tools with water after each use. 9.) May be reapplied as needed to surface that is clean and dry.
A single 1 Litre bottle will cover approximately 8 m2 to 25 m2 (80 to 265 sq. ft.) per coat, depending on type, porosity and texture of surface, temperature, humidity, and method of application.
1 Litre bottles £16.00 each. Post and Packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items.
5 Litre bottles £69.00 each. Post and Packing £10.00 (Incl.VAT) for 1 or more items.
Limitations
Handling & Storage
♦ Do not allow sealer to come into contact with any non-recommended surfaces.
♦ May slightly lighten or darken some surfaces
♦ Will not prevent wear or etching from acids or caustic chemicals.
♦ Close container after each use.
♦ Store in original Container only.
♦ Store and use in temperatures between 4° C and 38° C (40° F and 100° F)
♦ Unused, stored product is freeze-thaw stable.
PRECAUTIONS
♦ KEEP OUT OF REACH OF CHILDREN
♦ If spraying avoid inhaling mists
♦ Gloves should be worn during application
IF INGESTED:
Do not induce vomiting. Drink 1 to 2 glasses of water.
EYE AND SKIN CONTACT:
Flush immediately with water, if irritation persists seek medical attention
