TILE DOCTOR ® Seal and Go Extra Sealer |
Tile Doctor Seal & Go Sealer |
A special acrylic based formula which allows moisture vapour transmission making it fully breathable and ideal for situations where no damp proof membrane has been installed and mineral salt deposits (efflorescence) occur. |
Use on internal or external Victorian floor tiles, Sandstone, Flagstones, Terracotta, Saltillo and rough Slate.
2.) For new installations sealer can be applied as soon as 48 hours after grouting.
3.) Surface must be clean, dry, and free of existing sealers or coatings.
4.) Apply using a sponge or paint pad applicator. Avoid puddling.
5.) If two or more coats are applied, allow a minimum of 30 minutes drying time between coats.
6.) 2 hours after final coat conduct a test to determine if surface is completely sealed by applying water droplets to the surface. If water is absorbed, apply an additional coat. Wait 2 hours and repeat the test.
7.) Ready for surface traffic 6 hours after final coat. Keep area dry for at least 6 hours. Achieves a full cure in 24 hours.
8.) Clean applicator tools with water after each use.
9.) May be reapplied as needed to surface that is clean and dry.
Concrete Tile
Saltillo Tile
TerraCotta Tile
Victorian Tile
Coverage |
A single 1 Litre bottle will cover approximately 8 m2 to 25 m2 (80 to 265 sq. ft.) per coat, depending on type, porosity and texture of surface, temperature, humidity, and method of application. |
1 Litre bottles £20.00 each. Post and Packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items.
5 Litre bottles £89.00 each. Post and Packing £10.00 (Incl.VAT) for 1 or more items.
♦ Do not allow sealer to come into contact with any non-recommended surfaces.
♦ Do not get in eyes, on skin, or on clothing.
♦ Close container after each use.
♦ Store in original Container only.
♦ Read label before use. |
♦ If spraying avoid inhaling mists |
♦ Gloves should be worn during application |
IF SWALLOWED: | rinse mouth. Do NOT induce vomiting.. |
IF INHALED: | Remove person to fresh air and keep comfortable for breathing |
EYE CONTACT: | Bathe the eye with running water for 15 minutes. |
SKIN CONTACT: | Immerse in cool water. |
| Should any symptoms persist seek medical attention. |
