Tile Doctor Concentrated Neutral Tile And Grout Cleaner    Tile Doctor Pro-Clean Tile And Grout Cleaner    Tile Doctor Grout Clean-Up    Tile Doctor Pro-Clean Tile And Grout Cleaner    Tile Doctor Remove & Go Sealer and Adhesive Remover    Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner
     TILE DOCTOR ®           Concentrated Neutral Tile and Stone Cleaner
Concentrated Neutral Tile & Stone Cleaner
Most tile cleaning products sold on the market today are designed for cleaning ceramic rather than stone surfaces, as a result they can slowly etch away at the sealed surface of your stone floor reducing the life of your sealer. Tile Doctor concentrated Neutral Tile and Stone cleaner has been especially formulated for the regular cleaning of Sealed Stone and Tile surfaces keeping them fresh with a pleasant mint scent.
It’s PH neutral phosphate free formula ensures your sealed surface remains undamaged eliminating soap scum build up, hard water deposits and its super-concentrated so one bottle is enough to make up to 121 litres.
Tile Doctor Concentrated Tile Cleaner
Use on Grout, Natural Stone floor, Ceramic, Porcelain, Adobe Tile, Quarry, Terracotta, Masonry surfaces or other water-safe surfaces. This cleaner is ideal for sealed floors, its neutral PH formula will not degrade the sealer.
Method of Application Recommended for the following Surfaces
2.) Sweep or vacuum surface to remove loose debris.
3.) Mix 35-125ml of cleaner to 4 Litres of water.
For polished Natural Stone surfaces, 35ml of cleaner to 4 litres of water is usually sufficient.
4.) Apply solution to area to be cleaned.
5.) Agitate with a mop or soft-bristle brush.
6.) Mop up dirty solution.
7.) Change cleaning solution at least every 25m² (250 sq. ft.) or as needed.
Adobe Tile
Ceramic Tile
(Glazed and Unglazed)
Masonary
Natural Stone
Porcelain Tile
Resilient Tile
TerraCotta Tile
Other Water-Safe Surfaces
Approximately 187m² to 675m² (1870 to 6750 sq. ft.) per 946ml bottle depending on dilution.
Handling & Storage
♦ Close container after each use.
♦ Store in original Container only.
♦ Unused, stored product is freeze-thaw stable.
946ml bottles £11.00 each.
Postage and packing is £6.00 for the first item and £3.00 for further quantities.
SPECIAL OFFER - Purchase any stone sealing product and receive a special £3 discount on this product.!
3.78 litre bottles £39.00 each.
Postage and packing is £9.00 for the first item and £4.50 for further quantities.
♦ KEEP OUT OF REACH OF CHILDREN
Safety Data
Sheet Download
♦ Do not take internally
♦ For prolonged use of product, wear rubber gloves.
IF INGESTED: Do not induce vomiting. Drink 1 to 2 glasses of water.
EYE AND SKIN CONTACT: Flush thoroughly with water.
♦ If irritation persists, seek medical attention.
