Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner 1 litre bottle Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner 1 litre bottle Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner 1 litre bottle Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner 1 litre bottle Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner 1 litre bottle Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner 1 litre bottle Tile Doctor Nanotech Ultra Clean Tile, Stone And Grout Cleaner 1 litre bottle
     TILE DOCTOR ®           NanoTech HBU Remover
NanoTech penetrating Tile & Stone Cleaner
NanoTech HBU (formerly known as Ultra Clean) is a Heavy Build-Up Remover designed to work where other cleaners won’t. It utilises nano-sized particles to penetrate below tough stains, dissolve and lift them out. Especially effective for cleaning rough or textured surfaces. Also removes factory applied waxes and floor finishes, coating sealers, light grout residue (including epoxy), rubber and pencil marks, light mineral deposits, ground-in dirt and most sealer residues. Nanotech HBU Remover is nontoxic, non-flammable and non-acidic. NanoTech Ultra Clean abrasive cream cleaner
Use on Porcelain, ceramic, polished and unpolished natural stone (such as granite, limestone, marble, slate, and travertine), grout, quarry tile, saltillo, terra cotta, cement pavers, masonry surfaces, and other stone, tile and grout surfaces.
Method of Application Recommended for the following Surfaces
TEST A SMALL AREA: According to application instructions to determine desired results.
2.) Sweep, vacuum or dust surface to remove any loose debris.
3.) Pre-wet surface with water.
4.) Apply NanoScrub™ directly to the pre-wet surface.
5.) Agitate with a white nylon pad, scrub brush or scrub machine.
6.) Remove the residue using a wet-dry vac machine.
7.) Rinse thoroughly with clean water. NanoTech can be used as a power booster, with Tile Doctor Pro-Clean according to directions. Apply chosen product to surface, add NanoTech and agitate mixture. Continue to follow directions on the chosen product making sure a clean water rinse is the final step to remove any remaining residue.
Cement Pavers
Ceramic Tile
Granite
Marble
Masonary Surfaces
Porcelain Tile
Saltillo
TerraCotta Tile
Travertine
Victorian
Approximately 5m² to 53m² (54 to 572 sq. ft.) per 1 litre bottle depending on dilution.
Handling & Storage
♦ Close container tightly after each use.
♦ Store in original container only.
♦ Store and use between temperatures of 4ºC and 32ºC (40ºF and 90ºF).
♦ Keep unused material sealed tightly.
♦ Unused, stored product is freeze-thaw stable.
1 litre tin at £23.00 each.
Postage & Packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items.
5 litre bottles at £90.00 each.
Postage and packing £10.00 (Incl. VAT) for one or more items
♦ KEEP OUT OF REACH OF CHILDREN
♦ DO NOT KNEEL on any surface where solution has been applied and not thoroughly rinsed off.
♦ Do not take internally
♦ Protect hands with rubber gloves, eyes with chemical goggles, and skin with protective clothing.
IF INGESTED:Do not induce vomiting. Drink 1 to 2 glasses of water.
EYE AND SKIN CONTACT:Flush thoroughly with water. If symptoms persist, seek medical attention.
