TILE DOCTOR ® Ultra Seal Premium Sealer |
Premium, no-sheen, natural-look, solvent-based penetrating sealer formulated to provide maximum stain protection, especially in food preparation and serving areas. May also be used as a pre-grouting sealer. Allows moisture vapor transmission. It is also an excellent grout sealer. |
Use on all natural stone (such as marble, granite, slate, travertine and limestone), porcelain, quarry, saltillo, terra cotta, cement pavers, masonry surfaces and other porous tile and grout where a natural look is desired. Effective for interior and exterior applications. |
2.) For new installations sealer can be applied as soon as 48 hours after grouting.
3.) Surface must be clean, dry, and free of existing sealers or coatings.
4.) Apply using a sponge, brush, paint pad, cotton towel, or sprayer. NOTE: Be sure any sealer that does not penetrate surface is polished dry off surface within 5 minutes of each application using absorbent paper or cotton towels.
5.) If 2 or more coats are applied, allow a minimum of 30 minutes drying time between coats.
6.) After 2 hours conduct a test to determine if surface is completely sealed by applying water droplets to the surface. If water is absorbed, apply an additional coat. Wait 2 hours and repeat the test.
7.) Ready for surface traffic in 2 hours after final coat. Keep area dry for 12 hours. Achieves a full cure in 24 hours.
8.) Clean applicator tools with mineral spirits after each use.
Adoquin/Cantera
Agglomerate
Brick
Concrete Tile
Granite
Marble
Porcelain Tile
Quartzite
Saltillo Tile
Shellstone
TerraCotta Tile
Terrazzo
Travertine
Coverage |
A one litre bottle will cover approximately 10 m2 to 25 m2 (100 to 350 sq. ft.) per coat, depending on type of stone, porosity and texture of surface, temperature, humidity, and method of application.
1 litre bottles £36.00 each. Postage packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items. |
♦ Do not allow sealer to come in contact with any non-recommended surfaces.
♦ May slightly darken some stone surfaces.
♦ Sealer will not prevent surface wear or etching from acids or caustic chemicals. |
♦ Close container tightly after each use.
♦ Store in original container only.
♦ Store and use in temperatures between 4°c and 32°c (40°F and 90°F).
♦ Dispose of residue or any unused leftover product in accordance with applicable government and local requirements.
PRECAUTIONS |
♦ WARNING: FLAMABLE. Keep away from heat and open flame.
| ♦ KEEP OUT OF REACH OF CHILDREN |
♦ Contains petroleum distillates.
| ♦ Use in well-ventilated areas.
| ♦ Avoid prolonged skin contact.
| ♦ Wear NIOSH approved respirator, solvent-resistant gloves, safety goggles, and protective clothing. |
IF INGESTED: | Do not induce vomiting. Drink 1 to 2 glasses of water. Call doctor immediately. |
EYE CONTACT: | Flush with water. If irritation persists, seek medical attention. |
SKIN CONTACT: | Wash immediately with soap and water. If irritation persists, seek medical attention. |
INHALATION: | Relocate to fresh air. If symptoms persist, seek medical attention. |
