TILE DOCTOR ® High Shine Sealer |
Tile Doctor High Shine Sealer is a specially formulated water-based blend of acrylic polymers that provides both a stain resistant surface seal and a durable high-sheen finish eliminating the need for two products. May also be used as a pre-grouting sealer. Is not affected by ultra-violet light. |
Use on textured natural stone (such as tumbled marble, flamed granite, slate, sandstone, and quartzite), textured ceramic (rough to the touch), textured porcelain (rough to the touch), quarry, saltillo, terra cotta, cement pavers, masonry surfaces and other textured stone, and tile where a high shine is desired. Effective for interior applications only. |
2.) For new installations sealer can be applied as soon as 48 hours after grouting.
3.) Surface must be clean, dry, and free of existing sealers or coatings.
4.) Apply using a sponge or paint pad applicator. Avoid puddling. 5.) If 2 or more coats are applied, allow a minimum of 30 minutes drying time between coats (most surfaces will require more than one coat).
5.) 2 hours after final coat conduct a test to determine if surface is completely sealed by applying water droplets to the surface. If water is absorbed, apply an additional coat. Wait 2 hours and repeat the test.
6.) Ready for surface traffic 6 hours after final coat. Keep area dry for at least 6 hours. Achieves a full cure in 24 hours.
7.) Clean applicator tools with water after each use.
Adoquin/Cantera
Brick
Concrete Tile
Shellstone
TerraCotta
Coverage |
One litre bottle will cover approximately 8 m2 to 25 m2 (86 to 270 sq. ft.) per coat, depending on type of stone, tile, porosity and texture of surface, temperature, humidity, and method of application. |
1 litre bottles £15.00 each. Postage and Packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items |
5 litre bottles £65.00 each. Postage & Packing £10.00 (Incl.VAT) for 1 or more items. |
♦ Do not allow sealer to come in contact with any non-recommended surfaces.
♦ May slightly darken some surfaces.
♦ Will not prevent surface wear or etching from acids or caustic chemicals. |
♦ Close container after each use.
♦ Store in original Container only.
♦ Store and use in temperatures between 4°c and 38°c (40°F and 100°F).
♦ Unused, stored product is freeze-thaw stable.
PRECAUTIONS |
♦ If spraying avoid inhaling mists |
♦ Gloves should be worn during application |
IF INGESTED: | Do not induce vomiting. Drink 1 to 2 glasses of water. |
EYE AND SKIN CONTACT: | Flush immediately with water, if irritation persists seek medical attention |
