TILE DOCTOR ® Oxy-Pro Shower Tile And Grout Cleaner |
Oxy-Pro Shower Tile and Grout Cleaner |
Spray on cleaning solution specially formulated for the cleaning of shower tiles |
A powerful high-alkaline cleaner especially formulated for cleaning shower Tile and Grout. Highly effective cleaner that removes soap scum, body oil, mildew and algae from areas that have been neglected or subjected to frequent use. |
Use on natural stone (such as Granite,
Limestone, Slate, and Travertine), Ceramic, Porcelain, Quarry, Saltillo, Terracotta
and Masonry surfaces.
AVOID ALL SKIN CONTACT.
2.) Put on Rubber Gloves and Eye Protection.
3.) Sweep, vacuum, or wipe surface.
4.) Spray solution onto surface.
6.) Allow to dwell 3 to 5 minutes for cleaning.
7.) Agitate with scrub brush. Do not allow solution to dry on surface.
8.) Wash of solution and Rinse thoroughly with clean water
PLEASE NOTE: Once dry we recommend Grout is protected with the application of a Grout Sealer.
Brick
Ceramic Tile
Concrete Tile
Granite
Porcelain Tile
TerraCotta Tile
Travertine
Coverage |
Approximately 10m² to 20m² (100 to 200 sq. ft.) per 1 Litre bottle depending on tile porosity. |
500ml spray bottles including scrubbing sponge £7.99 each. Postage & Packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items. |
Do not allow Oxy-Pro Tile and Grout Cleaner to come into contact with any non-recommended surfaces. |
♦ Close container after each use.
♦ Store in original Container only.
♦ Unused, stored product is freeze-thaw stable.
♦ Irritating to eyes and skin |
♦ Harmful if swallowed |
♦ Risk of serious damage to eyes. |
♦ Avoid contact with eyes, skin and mucous membranes
♦ Rubber gloves and eye protection should be worn during application. Promptly remove clothing soaked in solution.
IF INGESTED: | Wash out mouth with water. Do not induce vomiting. If conscious, give half a litre of water to drink immediately. Consult a doctor. |
EYE CONTACT: | Bathe the eye with running water for 15 minutes. Transfer to hospital for specialist examination. |
SKIN CONTACT: | Remove all contaminated clothes and footwear immediately unless stuck to skin. Wash. |
IF INHALED: | Remove casualty from exposure ensuring one's own safety whilst doing so. |
