TILE DOCTOR ® Aqua-Pro Regular Use Neutral Tile and Stone Cleaner |
Neutral Tile & Stone Cleaner |
The Tile Doctor range of neutral Tile and Stone cleaners are especially formulated for the regular cleaning of Sealed Stone and Tile surfaces keeping them fresh.
It’s PH neutral phosphate free formula ensures your sealed surface remains
undamaged eliminating soap scum build up, hard water deposits. |
Use on Grout, Natural Stone floor, Ceramic, Porcelain, Adobe Tile, Quarry, Terracotta, Masonry surfaces or other water-safe surfaces. This cleaner is ideal for sealed floors, its neutral PH formula will not degrade the sealer.
2.) Sweep or vacuum surface to remove loose debris.
3.) Apply solution to area to be cleaned.
4.) Agitate with a mop or soft-bristle brush.
5.) Mop up dirty solution and squeeze dirty water into a serperate bucket.
6.) Rinse with clean water.
Adobe Tile
Ceramic Tile (Glazed and Unglazed)
Masonary
Natural Stone
Porcelain Tile
Resilient Tile
TerraCotta Tile
Other Water-Safe Surfaces
Coverage |
Approximately 10m² to 15m² (100 to 150 sq. ft.) per 1 litre bottle depending on perosity of tile.
♦ Close container after each use.
♦ Store in original Container only.
♦ Unused, stored product is freeze-thaw stable.
500ml bottles £7.99 each. Postage & packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items.
♦ Do not take internally, if ingested drink large amounts of milk or water to dilute the product and seek medical attention. |
♦ For prolonged use of product wear rubber gloves. |
EYE CONTACT: In case of contact with eyes, rinse immediately with plenty of water and seek medical advice. |
