Tile Doctor Pro-Seal Premium Sealer    Tile Doctor Concentrated Neutral Tile And Grout Cleaner    Tile Doctor Pro-Clean Tile And Grout Cleaner    Tile Doctor Grout Clean-Up    Tile Doctor Remove & Go Sealer and Adhesive Remover    Tile Doctor Pro-Seal Premium Sealer
     TILE DOCTOR ®           Pro-Seal Premium Sealer for natural stone sealing
Tile Doctor Pro-Seal Premium Stone Sealer
Tile Doctor Pro-Seal Natural Stone Premium Sealer for Granite, Limestone, Marble, Porcelain, Slate, Terracotta and Travertine
A premium, no-sheen, natural look, water based, penetrating sealer formulated to provide maximum stain protection, especially in food preparation and serving areas. May also be used as a pre-grouting sealer. Allows moisture vapor transmission. It is also an excellent grout sealer.
Use for sealing all natural stone (such as granite, limestone, marble, slate and travertine), porcelain, quarry, saltillo, terracotta, cement pavers, masonry surfaces and other porous tile, stone and grout where a natural look is desired. Effective for interior and exterior applications
Method of Application Recommended for the following Surfaces
2.) For new installations sealer can be applied as soon as 48 hours after grouting.
3.) Surface must be clean, dry, and free of existing sealers or coatings.
4.) Apply using a sponge, brush, paint pad, cotton towel, or sprayer. NOTE: Be sure any sealer that does not penetrate surface is removed from surface within 5 minutes of application using absorbent paper or cotton towels.
5.) If 2 or more coats are applied, allow a minimum of 30 minutes drying time between coats.
6.) 2 hours after final coat conduct a test to determine if surface is completely sealed by applying water droplets to the surface. If water is absorbed, apply an additional coat. Wait 2 hours and repeat the test.
7.) Ready for surface traffic in 2 hours after final coat. Keep area dry for 12 hours. Achieves a full cure in 24 hours.
8.) Clean applicator tools with water after each use.
Concrete Tile
Granite
Marble
Porcelain Tile
Saltillo Tile
TerraCotta Tile
Travertine
A one litre bottle will cover approximately 7.5 m2 to 35 m2 (75 to 375 sq. ft.) per coat, depending on type of stone, tile, porosity and texture of surface, temperature, humidity, and method of application.
1 litre bottle £36.00 each.
Postage packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items.
Limitations Handling & Storage
♦ Do not allow sealer to come in contact with any non-recommended surfaces.
♦ May slightly darken some surfaces.
♦ Will not prevent surface wear or etching from acids or caustic chemicals.
♦ Close container after each use.
♦ Store in original Container only.
♦ Store and use in temperatures between 4°c and 38°c (40°F and 100°F).
♦ Unused, stored product is freeze-thaw stable.
RECAUTIONS
♦ KEEP OUT OF REACH OF CHILDREN
♦ If spraying avoid inhaling mists
♦ Gloves should be worn during application
IF INGESTED:Do not induce vomiting. Drink 1 to 2 glasses of water.
EYE AND SKIN CONTACT:Flush immediately with water, if irritation persists seek medical attention
