TILE DOCTOR ® Shine Powder for a Deep Durable Finish |
Tile Doctor Shine is a crystallising powder that provides a very high shine and tough durable finish |
Use for sealing all natural stone (such as granite, limestone, marble, slate and travertine), porcelain, quarry, saltillo, terracotta, cement pavers, masonry surfaces and other porous tile, stone and grout where a natural look is desired. Effective for interior and exterior applications |
2.) After regrinding and polishing the floor area with abrasives, ensure floor is cleaned of any slurry and vacuumed away. We recommend the floor should be finished to at least 400 Grade (Diamond). For maintenance as follows:
3.) Apply 20 grams of Powder to 1m2 of floor. Use a slow speed floor rotary machine (200rpm max.) fitted with a white or tan buffing pad. Place at least 1/2 ltr of water onto the floor and work product into floor for 3-5 minutes.
The resulting mixture when working the floor should be a green watery solution. Do not allow product to thicken up like a cream. Do not let the mixture dry out under floor machine.
4.) Remove any fluid and after the floor has dried polish with a rotary machine fitted with a white buffing pad, some spray burnishing may be required to release stubborn marks
Granite
Marble
Travertine
1 kg Tub £30.00 each. Postage packing £10.00 for 1 or more items.
♦ Do not allow product to come in contact with any non-recommended surfaces.
♦ Store in original Container only and away from Frost.
♦ Avoid Eye and Skin contact.
♦ Gloves and Protective Glasses should be worn during application |
IF INGESTED: | Rinse mouth and seek medical attention. |
SKIN CONTACT: | Wash immediately with water and rinse well. |
EYE CONTACT: | Flush immediately with water and seek medical attention |
