Mould Away Spray |
Mould Away is a Fast effective formula for removing mould off Silicone and Grout. |
Use |
Simply spray the Silicone or Grout to be treated with Mould Away then leave to soak in for five minutes and scrub with a brush or coarse pad, rinse with water, if necessary repeat process until the mould has disappeared. |
Read entire label before using.
1.) SHAKE WELL before using.
2.) Spray the surface to be treated from 3-5cm away.
3.) Leave to work for 20-30 mins, then agitate with a stiff brush or scouring pad.
4.) In the case of stubborn stains i.e. such as on silicone selalants, spray again and leave to work for up to 2-3 hours.
5.) Clean the sprayed surface with a sponge and clean water.
Always test MOULD AWAY on an inconspicuous area prior to use.
500ml bottles available at £12.00 each. |
Postage & Packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items. |
Silcone
♦ Close nozzle after each use.
♦ Store in original container out of direct sunlight.
