Mapei Primer G    Mapei Rapid-Set Ceramic floor tile adhesive    Mapei Keraquick Ultrarapid-setting flexible adhesive.    Mapeigrip Plus Waterproof wall adhesive    Mapei Mapeistick ready-to-use, non-slip paste adhesive for ceramic tiles.    Mapei Ultracolour waterproof flexible wall and floor grout    Mapei Mapeisil Silcone
Mapei Grout and Adhesive Products
Tile Doctor recommends Mapei Grout and Adhesive products
Mapei Rapid-Set floor tile adhesive
Mapei Rapid-Set quick drying cement based floor tile adhesive for internal and external ceramic floor tile installations, available in standard Grey or White.
Data Sheet for Mapei Rapid-Set quick setting cement based floor tile adhesive Data Sheet
Mapei Rapid-Set quick drying cement based floor tile adhesive for internal and external ceramic floor tile installations/a>
20kg bag of Mapei Rapid-set floor tile adhesive £18.00 each.
Postage and packing is £7.95 for the first item and £4.00 for further quantities.
Colour?
Ultrarapid-setting flexible (S1) cement based powder adhesive for ceramic tiles (thicknesses of adhesive up to 7 mm).   Applications include interior and exterior bonding of all types of ceramic floor and wall tiles (double fired tiles, single fired, porcelain tiles etc) on old floors and walls (ceramic tiles, natural stone, terrazzo, concrete) provided they are solid and clean; cast concrete, properly cured prefabricated concrete panels (at least 4 months old), heating panels, reinforced cement panels, plaster boards, provided they are firmly fixed. Particularly suitable for works where rapid repairs are required spacing.
Available in Grey or White, Coverage 2.5-4 kg/m2.
Data Sheet for Mapei Keraquick ultra rapid setting ceramic floor tile adhesive Data Sheet
Mapei Keraquick Ultrarapid-setting flexible cement based powder adhesive
20kg bag of Mapei Keraquick tile adhesive £25.00 each.
Colour?
Brilliant white, slip resistant, flexible, water-resistant paste adhesive for ceramic tiles. Use for bonding all types of ceramic tiles and mosaics to a wide wareity of backgrounds including those with slight deformations. Use on Internal walls only, can be used on wet duty areas including washrooms and showers.
Data Sheet for Mapei Mapeigrip Plus waterproof wall adhesive Data Sheet
Mapei Mapeigrip Plus Waterproof wall adhesive
15kg Mapeigrip Plus Waterproof wall adhesive £7.95
Postage and packing is £4.00 for the first item and £2.00 for further quantities.
High grab, ready-to-use, non-slip paste adhesive for ceramic tiles. For use on interior walls. Ideal for tiling on to plaster and plaster board backgroud. Classified as D1T in accordance with EN12004. Coverage 2,5 kg/m2 n°5 travel.
Data Sheet for Mapei Mapeistick ready-to-use, non-slip paste adhesive for ceramic tiles Data Sheet
Mapei Mapeistick adhesive for ceramic tiles
15kg tub of Mapei Mapeistick tile adhesive £12.00 each.
A fast setting and drying grout for 2 to 20 mm joints, available from Tile Doctor in 6 colours.
Use for interior and exterior grouting on all types of ceramic walls and floor tiles (double fired, single fired, klinker, porcelain, terracotta, etc.), glass mosaic, natural stone, concrete-framed glass blocks, etc. Easy to apply and finish.
Ensures perfect colour evenness, does not produce surface efflorescence, dries rapidly, therefore floors and coverings are ready for traffic rapidly.
Suitable for grouting joints on external façades, balconies, terraces, swimming pools, bathrooms and kitchens. Particularly suitable for grouting floor joints of supermarkets, motorway services, restaurants, airports and public premises. Coverage depending on the size of the joint.
Data Sheet for Mapei Ultracolour waterproof flexible wall and floor grout Data Sheet
5kg bag of Mapei Ultracolour grout £11.00 each.
Colour?
Mapei Mapeisil AC Silcone
Solvent-free, acetic-crosslinking mildew-resistant silicone sealant, available from Tile Doctor in 2 colours and transparent.
Sealing interior and exterior expansion joints with ± 20% expansion of the initial size in interior and exterior ceramic tiled, floors and walls in swimming pools, bathrooms and showers. Mapesil AC can also be used to create perfectly flexible gaskets between construction elements in building, mechanical engineering, ship-building, automobile manufacturing etc.
N.B. Mapesil AC perfectly adheres to glass, ceramic and anodised aluminium. When first treating with Primer FD, Mapesil AC adheres well also on concrete, wood, metal, painted surfaces, plastic, rubber etc. Coverage depends on the size of the joint. Packaging 310 ml cartridges.
Data Sheet for Mapei Mapeisil Silcone Data Sheet
Tube of Mapei Mapeisil Silcone £6.75 each.
Colour?
Mapei Synthetic resin based water dispersion primer
Use for treating gypsum or anhydrite surfaces prior to applying cement-based products (Kerabond, Ultraplan, Nivoplan, etc.). Treating cement-based surfaces (cast concrete and prefabricated walls etc.) prior to laying gypsum-based plasters. The substrate must be clean and absorbent. Coverage 100-200 g/m2 depending on use.
Mapei Primer G
1kg Mapei Primer G £5.75 each.
Add to your shopping basket
Click for more details
