17 Inch Mega  60-Grit Carborundum Silicone Carbide Brush
17 Inch Mega 60-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
Leicestershire Tile Doctor
Based in Leicester Adam and his father Steve are your your local tile, stone and grout specialists providing cleaning, sealing and restoration services across all types of stone and tile.
Victorian Tile Cleaning Information
Help with Tile and Stone  >  Victorian Tile Cleaning
Victorian tiles are the ancestors of the modern Quarry tiles, the standard bearer for quality was a firm known as Minton Hollins an English manufacturer who unlike their competitors managed to make a very good product which has lasted the test of time; however all these types of tile were subject to Victorian building practice of the day and damp issues and salt problems (efflorescence) are quite common with these tiles.  As such Tile Doctor has worked alongside tile cleaning agents to improve the products currently on the market.
Cleaning Victorian Tiles
  • For deep cleaning and heavily soiled and neglected areas apply a solution of Tile Doctor Pro-Clean diluted 1:5 with water to the tiles directly. Leave to soak for ten minutes then agitate with a scrubbing brush or black pad fitted to a buffer machine. Extract soiled solution with a wet vacuum and then rinse thoroughly with water and vacuum again. To strip off waxes and acrylic sealers a stronger 1:2 dilution can be used.
  • If glue from carpet grippers is present use Tile Doctor NanoTech HBU instead which is product designed to remove heavy dirt build-up and adhesives.
  • If cement or grout haze (grout smears) is present use Tile Doctor Grout Clean-up which is a phosphoric acid that can break down the cement. Extract solution with a wet vacuum and then rinse thoroughly with water and vacuum again.
To prevent possible salt issues (efflorescence) after cleaning use neat Tile Doctor Acid Gel and leave to soak into the tile for a maximum of ten minutes and then scrub with a deck brush adding water as you go. Extract solution with a wet vacuum and then rinse thoroughly with water and vacuum again. This will impede possible salt issues oxidising to the surface of the tile leaving white marks. Do not start sealing until all the white marks have disappeared and repeat the Acid Gel treatment in two to three days time should the salts re-appear.
Sealing Victorian Tiles
Original Victorian tiles were fitted without a DPM (damp proof membrane) as such it is widely recognised that the tiles should left to dry for several days following any deep cleaning to ensure the tiles are dry (especially during winter time and following periods of high rain fall), a damp meter is recommended to test for this.
  • If a matt finish is preferred we recommend two or three coats of Tile Doctor Colour Grow, this has a colour enhancing agent that will improve the look of the tile. Additionally Colour Grow is a fully breathable solvent based impregnating sealer and provided the floor is dry before the sealer is applied the sealer will fully cure in 24 hours but can be walked on after a few hours of being sealed.
    Edwardian Tiled Hallway Floor Sealed with Colour Grow in Wombwell
  • If a deep satin finish is required then we recommend Tile Doctor Seal and Go which adds a nice sheen and lift the appearance of the tile, however this is an water based acrylic sealer and like Goldilocks porridge the conditions have to be perfect for this to work, i.e. no damp and no salts.  Please note Seal and Go is not recommended for external applications.
  • If a satin finish is required and the conditions of the installation are not perfect as described in option 2 we recommend Tile Doctor Seal and Go Extra which provides a lower sheen finish and can be used internally and externally as being a fully breathable sealer it is not affected by damp or salt issues.  Please note as with all sealers the conditions need to be fully dry at the time of application to allow the sealer to fully cure, once cured (24 hours later) it will provide the required protection similar to Option 1.
Reproduction Victorian Floor Tiles
These modern type of tiles unlike their predesessor are a lot less porous and can be cleaned using the same techniques as original Victorian floor tiles however when it comes to sealing these tiles it is important to do a small test first because the sealer may be not be abosrbed by the tile due their low porosity.  The sealer we recommend for these tiles is called Tile Doctor Colour Grow which is a matt finish sealer and will lift the colour of the clay; one or two coats should suffice.
Maintenance Cleaning
Always use a PH neutral cleaner such as Tile Doctor Concentrated Neutral Cleaner which once diluted with water becomes completely PH neutral unlike bleaches and washing up liquids which are not neutral and can damage the sealer with prolonged usage.
Sealers will wear down over time depending on use so it is recommended to top up your floor sealer once a year with the original sealer; one coat should be sufficient and by doing this it will save a lot of time and expense in having to deep clean the tiles and re-seal every three to five years.
Victorian Hallway restored to its former glory by the Kent Tile Doctor
Victorian Tile before being cleaned by Kent Tile Doctor
Tiles before Cleaning & Sealing
Victorian Tile after being cleaned by Kent Tile Doctor
Tiles after Cleaning & Sealing
For many more examples of Victorian tile cleaning and sealing activities carried out by UK Tile Doctors please visit http://Victorian.TileCleaning.co.uk
Recommend Products for Victorian Tiles
17 Inch 100 Grit Very Coarse Milling Pad
17 Inch 100 Grit very coarse diamond milling Pad for resurfacing rough stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
17 Inch 200 Grit Coarse Milling Pad
17 Inch Coarse 200-grit diamond Milling Pad for resurfacing stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
Flexi Segment  6 Inch  200 grit Diamond Floor Pad
6 inch 200 grit Diamond Floor Pad with Flexi Segment
£60.50
Tile Doctor Seal & Go 1 litre
Tile Doctor Seal & Go Extra 1 Litre
All the information you need to be able to clean and maintain Victorian floor and wall tiles.
