Julian is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Victorian Tile Cleaning
![]() Victorian tiles are the ancestors of the modern Quarry tiles, the standard bearer for quality was a firm known as Minton Hollins an English manufacturer who unlike their competitors managed to make a very good product which has lasted the test of time; however all these types of tile were subject to Victorian building practice of the day and damp issues and salt problems (efflorescence) are quite common with these tiles. As such Tile Doctor has worked alongside tile cleaning agents to improve the products currently on the market. Cleaning Victorian Tiles
To prevent possible salt issues (efflorescence) after cleaning use neat Tile Doctor Acid Gel and leave to soak into the tile for a maximum of ten minutes and then scrub with a deck brush adding water as you go. Extract solution with a wet vacuum and then rinse thoroughly with water and vacuum again. This will impede possible salt issues oxidising to the surface of the tile leaving white marks. Do not start sealing until all the white marks have disappeared and repeat the Acid Gel treatment in two to three days time should the salts re-appear. Sealing Victorian TilesOriginal Victorian tiles were fitted without a DPM (damp proof membrane) as such it is widely recognised that the tiles should left to dry for several days following any deep cleaning to ensure the tiles are dry (especially during winter time and following periods of high rain fall), a damp meter is recommended to test for this.
Reproduction Victorian Floor TilesThese modern type of tiles unlike their predesessor are a lot less porous and can be cleaned using the same techniques as original Victorian floor tiles however when it comes to sealing these tiles it is important to do a small test first because the sealer may be not be abosrbed by the tile due their low porosity. The sealer we recommend for these tiles is called Tile Doctor Colour Grow which is a matt finish sealer and will lift the colour of the clay; one or two coats should suffice. Maintenance CleaningAlways use a PH neutral cleaner such as Tile Doctor Concentrated Neutral Cleaner which once diluted with water becomes completely PH neutral unlike bleaches and washing up liquids which are not neutral and can damage the sealer with prolonged usage. Sealers will wear down over time depending on use so it is recommended to top up your floor sealer once a year with the original sealer; one coat should be sufficient and by doing this it will save a lot of time and expense in having to deep clean the tiles and re-seal every three to five years.
For many more examples of Victorian tile cleaning and sealing activities carried out by UK Tile Doctors please visit http://Victorian.TileCleaning.co.uk Recommend Products for Victorian TilesWhen using our products please take time to familiarise yourself with the directions on the back of the bottle first.
6 inch 200 grit Diamond Floor Pad with Flexi Segment
£60.50
17 Inch Coarse 200-grit diamond Milling Pad for resurfacing stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
17 Inch 100 Grit very coarse diamond milling Pad for resurfacing rough stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
