Covering South Buckinghamshire Jack is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Mark covers the county of Worcestershire providing specialist tile, stone and grout cleaning, sealing and restoration services across all types of tile and stone, wall or floor.
Tile Doctor Products >
Tile Buffing
![]() Sixteen inch Buffing pads for Cleaning, Buffing and Polishing tiled floors. To be used with a standard rotary floor machine.
Tan Buffing pad 17" (44cm), dry cleaning, polishing and maintenance cleaning, use with Neutral Cleaner after floor is washed and dried to give that finishing touch to the floor.
6 inch White Buffer pads for use with a hand buffing machine to lightly polish and clean polished surfaces without causing scratches.
£5.25
White Buffing pad 17" (44cm), for light polishing and general regular maintenance cleaning of polished stone surfaces. Can be used in conjunction with Neutral Tile Cleaner or Stone Soap.
Red Buffing pad 17" (44cm), dry cleaning, polishing and maintenance cleaning, use with Neutral Cleaner after floor is washed and dried to give that finishing touch to the floor.
Green Buffing pad, pad 17" (44cm), for medium duty cleaning, can be used on all types of floor (except polished stone), use with Tile Doctor Pro-Clean to remove general dirt and grime.
Tile Doctor High Shine Crystallising Powder adds a Very High Shine to Limestone, Marble, Slate and Travertine.
