Tan Buffing pad 17" (44cm), dry cleaning, polishing and maintenance cleaning, use with Neutral Cleaner after floor is washed and dried to give that finishing touch to the floor.
17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
Tile Doctor Products >
Stone Burnishing
![]() Made with industrial diamonds and available in different sizes and grits, burnishing pads are ideal for restoring the appearance of polished stone walls and floors. Uses:
DemonstrationMethod of Application:
4 inch diamond wet and dry polishing pad, step 3 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 2 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 1 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
17 Inch Mega 240-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
£195.00
17 Inch Mega 60-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
2nd step Polishing, to smooth down rough surface, ready for final polishing, clean grout lines after using this pad.Use only Water.
1st step polishing, to grind off ingrained dirt and worn surface, use only with water.
£50.00
Coarse Burnishing pad for the removal of sealers and resurfacing of scratched surfaces, use only with water.
£50.00
