Tile Doctor Stone Patina Spray 500ml
A spray-and-buff cleaner that is designed to enhance the natural beauty and lustre of polished stone as it cleans. Regular use helps protect factory polish.
 6 Inch  800 Grit Medium No.2 Burnishing Pad
Initial polish, only use with water.
Tile Doctor | Burnishing pads for professional stone polishing
Tile Doctor Products  >  Stone Burnishing
Stone Burnishing
Made with industrial diamonds and available in different sizes and grits, burnishing pads are ideal for restoring the appearance of polished stone walls and floors.
  • Six inch burnishing pads are designed to fit a hand held buffing machine to restore polished stone walls and tricky to reach floor areas.
  • Seventeen inch pads are used with weighted rotary floor machines to remove dirt and restore the polished stone finish.
  • We also supply Milling Pads which are very coarse low grit pads that can reduce and level the surface of a stone floor; ideal for stone floors where the tiles have not been laid evenly and have lippage issues. For more information on Milling please see our dedicated Milling page.
  • Start with low grit pads and work you way through from coarse, medium, fine and very fine pads to restore polish and appearance.
  • Use water to lubricate the process and extract the resulting slurry after each pad.
  • Run the pad evenly over each part of the stone floor unil at least three passes have been performed.
 4 Inch Diamond Wet and Dry Polishing Pad - Step 1
4 inch diamond wet and dry polishing pad, step 1 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
 4 Inch Diamond Wet and Dry Polishing Pad - Step 2
4 inch diamond wet and dry polishing pad, step 2 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
 4 Inch Diamond Wet and Dry Polishing Pad - Step 3
4 inch diamond wet and dry polishing pad, step 3 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
 6 Inch  400 Grit Coarse No1. Burnishing Pad
Ideal for removing sealers.
 6 Inch 1500 Grit Fine No.3 Burnishing Pad
Second polish, only use with water.
 6 Inch 3500 Grit Very Fine No.4 Burnishing Pad
Final polish, use with a water spray.
 6 inch Set of four Burnishing Pads inc  No 1,2,3 and 4
17 Inch   400-Grit Coarse No.1 Burnishing Pad
Coarse Burnishing pad for the removal of sealers and resurfacing of scratched surfaces, use only with water.
£50.00
17 Inch   800 Grit Medium No.2 Burnishing Pad
1st step polishing, to grind off ingrained dirt and worn surface, use only with water.
£50.00
17 Inch  1500-Grit Fine No.3 Burnishing Pad
2nd step Polishing, to smooth down rough surface, ready for final polishing, clean grout lines after using this pad.Use only Water.
17 Inch  3500-Grit Very Fine No.4 Burnishing Pad
17 Inch Mega  60-Grit Carborundum Silicone Carbide Brush
17 Inch Mega 60-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush
17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
17 Inch Mega 240-Grit Carborundum Silicone Carbide Brush
17 Inch Mega 240-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
Cleaning, Burnishing and Polishing accessories for Stone and Tile Cleaning
