Staffordshire Tile Doctor
Trevor is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Tile Doctor Stone Patina Spray 500ml
A spray-and-buff cleaner that is designed to enhance the natural beauty and lustre of polished stone as it cleans. Regular use helps protect factory polish.
Quarry Tile Cleaning Information
Help with Tile and Stone  >  Quarry Tile Cleaning
A classic hard wearing tile often utilised in high traffic areas such as reception areas, toilets and outdoor patio areas and porches. Although hard wearing Quarry tiles are often neglected and end up hidden under years of grime; however all is not lost they can be restored, see below for details:
Quarry Tile Maintenance
Deep Cleaning Quarry Tiles
  • To remove old sealers and other coatings use Tile Doctor Remove & Go Sealer remover.
  • Clean the floor using Tile Doctor Pro-Clean Heavy Duty Tile and Grout Cleaner which is highly effective against Wax Sealers, Grease, Grime and general dirt build up.
  • For difficult floors mix Pro-Clean with Nanotech Ultra Clean for a double whammy cleaning solution. Nanotech-Ultra Clean incorporates Nano technology to help lift the dirt from the tiles (it really works), especially useful for those hard to clean floors where the dirt has ingrained itself over many years.
  • Extract the soiled cleaning solution using a wet vacuum and then neutralise the floor by rinsing with water again using a wet vacuum to remove as much water was possible after.  (Any cleaning products left on the surface may impact the performance of the sealer).  Allow the tiles to dry out for at least 12 hours or more.
  • To resolve Efflorescence issues where white salts appear on the surface of the tile please read the information on the Treating Efflorescence web page.
  • For a low sheen finish on internal floors apply Tile Doctor Seal & Go sealer using a paintpad applicator and tray. 4 to 5 coats of sealant may be required, always allow to dry before applying further coats.
  • For a low sheen finish on external floors or those with damp issues apply Tile Doctor Seal & Go Extra sealer using a paintpad applicator and tray. 4 to 5 coats of sealant may be required, always allow to dry before applying furhter coats.
  • Alternatively for external areas or a matt finish use Tile Doctor Ultra Seal sealer using a paintpad applicator and tray. Slate tiles may require up to 2 or 3 coats, always allow to dry before applying the next coat.
  • Use a water test to check for full cure sealability (F.C.S.).  (A drop of water will form a bubble on fully sealed floor)
Maintenance Cleaning
Most sealers break down after 2-3 years (depending on usage and cleaning products used) so for regular cleaning use a sealer friendly cleaning product such as Tile Doctor Neutral Tile Cleaner which has been especially formulated for the regular cleaning of Sealed Stone and Tile surfaces keeping them fresh with a pleasant scent.
Recommend Products for Quarry Tiles
When using our products please take time to familiarise yourself with the directions on the back of the bottle first. For many examples of Quarry tile cleaning and sealing activities using these products and out by UK Tile Doctors please visit http://Quarry.TileCleaning.co.uk
17 inch Buffing Pad Black
Tile Doctor Colour Grow Sealer 5 Litre
£138.40
Tile Doctor Pro-Seal Premium Sealer 1 Litre
£39.20
Tile Doctor Seal & Go 1 litre
Tile Doctor Seal & Go Extra 1 Litre
Tile Doctor Seal & Go Extra 5 Litre
A special acrylic based formula which allows moisture vapour transmission making it fully breathable and ideal for situations where no damp proof membrane has been installed and mineral salt deposits (efflorescence) occur.
£112.90
Tile Doctor Shine Powder 1kg Tub
Tile Doctor Shine is a crystallising powder that provides a very high shine and tough durable finish on polished stone.
All the information you need to be able to clean and maintain Quarry floor and wall tiles.
