Servicing West Cheshire, Alistair Robb along with his son Andrew are your local specialists for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tile
Steve is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Porcelain Tile Cleaning
![]() Harder than ceramic tiles modern production methods have spurred a growth in the availability and design of Porcelain tiles which are known for their durability and water resistance making them a popular option for floors. Porcelain tiles come in three categories and its well worth knowing which type you have in order to maintain them properly, it can be very difficult to tell so if your unsure you will need to ask your supplier.
Cleaning Porcelain TilesPorcelain tiles are generally fully glazed, even the matt porcelain tile is fully glazed so this means they won't need to be sealed unless they are textured (see below) however the textured tiles can trap dirt in the groves (unless sealed) and thus will need to be cleaned out with Tile Doctor Pro-Clean and rinsed with water afterwards. Polished Porcelain tiles generally only require a light clean using Tile Doctor Neutral Cleaner where only a couple of cap fulls diluted in a bucket of warm water should be sufficient. Additionally We find that a Green No. 4 Burnishing pad attached to a slow speed buffing machine will polish up the porcelain to a very high shine, then use a vacuum to remove any dust created. Using excessive amounts of cleaning agents on polished porcelain actually creates problems with chemical build-up so the method recommend above is the correct process for these type of tiles.
Most Ceramic tiles are quite easy to clean with these methods however grout is normally recessed and this can act as a dirt trap on floor tiles when they are mopped leading to a build-up of dirt on the grout, this can be resolved using Tile Doctor Pro-Clean and then once clean and fully dry, seal the grout with one coat of Tile Doctor Ultra-Seal applied using a pipette along the grout line. Sealing Porcelain TilesHere at Tile Doctor we often get asked to recommend a sealer for Porcelain Tiles; the simple answer is they don't usually need one however there are a couple of exceptions: For many examples of Porcelain tile cleaning activities carried out by UK Tile Doctors please visit http://Porcelain.TileCleaning.co.uk
Recommended Products for Porcelain TilesWhen using our products please take time to familiarise yourself with the directions on the back of the bottle first.
700005
Easy-to use waterborne epoxy that recolours, seals and rejuvenates existing grout joints. Recommended for use on sanded, unsanded and epoxy grout joints.
210237
£26.80
All-in-one Grout Colourant kit to prep, recolour and seal your grout joints. Kit contains 237ml Grout Colorant, 750ml Grout Colorant Pre-Treat Cleaner, grout brush and scrub pad.
210401
£35.00
Effective ready-to-use cleaner designed to lightly etch and also remove dirt, soil, soap scum and hard water deposits from grout joints. Use before applying Grout Colourant to prepare the grout joints for a superior bond with the Grout Colourant.
210502
£11.90
776100
724500
781052
£10.80
770946
730246
760946
779100
£24.50
775100
£103.10
740246
745246
