17 Inch 100 Grit very coarse diamond milling Pad for resurfacing rough stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
Barry and his team are your local specialists for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Marble Tile Cleaning
![]() Often reputed in the international market for its premium quality, toughness and durability. It is often the preferred choice for interior and exterior in both commercial and domestic for flooring, wall cladding, paving, facades of buildings, railway stations, pavement, landscaping, garden stone. Floor Tile Cleaning
Wall Tile Cleaning
Sealing Marble Tiles
Regular Maintenance of Marble
PLEASE NOTE: Sealers break down after 2-3 years (depending on usage) and will need to be re-applied. For many examples of Marble cleaning and sealing activities carried out by UK Tile Doctors please visit https://Marble.tilecleaning.co.uk Recommend Marble Cleaning ProductsWhen using our products please take time to familiarise yourself with the directions on the back of the bottle first.
4 inch diamond wet and dry polishing pad, step 1 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 2 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 3 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
£10.80
£39.20
Tile Doctor Shine is a crystallising powder that provides a very high shine and tough durable finish on polished stone.
A spray-and-buff cleaner that is designed to enhance the natural beauty and lustre of polished stone as it cleans. Regular use helps protect factory polish.
£14.40
