Covering the Northern half of the County of Essex Dean is your local Tile Doctor providing specialist tile, stone and grout cleaning, sealing and restoration services across all types of stone and tile.
Limestone Tile Cleaning
![]() The advice below will help you maintain Limestone to a good standard however please note Limestone is a sedimentary stone as such it’s generally very porous and acid sensitive, as such it can be damaged through the use of even mildly acidic soaps, shampoos and body washes and as a result is not recommended for use in wet rooms, shower cubicles or near swimming pools. Floor Tile Cleaning
Wall Tile Cleaning
Restoring Colour
Sealing Limestone Tiles
Regular Maintenance of Limestone
PLEASE NOTE: Sealers break down after 2-3 years (depending on usage) and will need to be re-applied. For many examples of Limestone cleaning and sealing activities carried out by UK Tile Doctors please visit https://limestone.tilecleaning.co.uk Recommend Limestone Cleaning ProductsWhen using our products please take time to familiarise yourself with the directions on the back of the bottle first.
4 inch diamond wet and dry polishing pad, step 1 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 2 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 3 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
£10.80
£39.20
Tile Doctor Shine is a crystallising powder that provides a very high shine and tough durable finish on polished stone.
£16.90
£76.10
£14.40
