Yellow 400 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
£22.25
Designed for professionals, Tile Doctor Patio & Brick Driveway Cleaner is a powerful outdoor cleaning solution formulated to power through patio blackspots, lichen, moss, and stains.
Encaustic Cement Tile Cleaning
![]() Made from layers of cement, Encaustic tiles are often hand painted with patterns hydraulically pressed into the surface resulting in a large range of beautifully artistic patterns with some companies offering a bespoke design service. They are known for their durability making them a popular option for floors. Like Ceramic, Encaustic tiles are generally very easy to clean and generally need little maintenance. Cleaning and MaintenanceEncaustic tiles however being made from cement are micro porous and so should be sealed to avoid dirt becoming trapped in the pores of the tile which will make them difficult to clean. Once sealed make sure you only use a neutral PH cleaning product to clean the tiles as stronger products (especially acidic) will reduce the life of the sealer. Floor Tile Cleaning
Sealing Encaustic Tiles
Regular Maintenance of Encaustic Tiles
PLEASE NOTE: Sealers break down after 2-3 years (depending on usage) and will need to be re-applied. For many examples of Encaustic tile cleaning activities carried out by UK Tile Doctors please visit http://Encaustic.tilecleaning.co.uk
Recommended ProductsWhen using our products please take time to familiarise yourself with the directions on the back of the bottle first.
700010
750246
750946
761000
761500
779100
£24.50
775100
£103.10
741000
