Rust Away |
Rust-Away is used to remove embeded rust stains on any type of Stone or Clay based tile including Terracotta, Porcelain and Ceramic Tile. |
Rust-away is a ready to use non-acidic formula and can be applied neat from the bottle and leave to dwell. After a few minutes you should notice that the rust stain turns a shade of purple as the rust starts to oxidise which is quite normal and to be expected. After no more than ten minutes apply enough water to fully cover the stain and scrub with a stiff brush, then either use a wet vacuum or sponge and cloths to remove the product. Note: we recommend you wear protective gloves during this activity.
If some rust stains remain you can repeat the process, for best results try a small test area first. do not leave Rust-Away for longer than ten minutes otherwise an etch mark may appear around the original rust stain.
1 litre bottles available at £22.00 each incl VAT. |
Postage & Packing £7.50 (Incl.VAT) for 1 litre, £10 (Incl.VAT) for two or more litres. |
Handling & Storage
♦ Avoid contact with skin and eyes.
♦ Keep away from acids and chlorinated hydrocarbons.
♦ Care should be taken when diluting solutions.
♦ Do not spray,
avoid generation of aerosols or mist.
♦ Keep container tightly closed.
PRECAUTIONS |
♦ Do not breathe dust/fume/gas/mist/vapours/spray. |
♦ Wear protective gloves/protective clothing/eye protection/face protection. |
INGESTION: | Do not induce vomiting. Provided the patient is conscious, wash out mouth with water and give 200-300 ml (half a pint ) of water to drink. |
INHALATION: | Remove patient from exposure, keep warm and at rest. Administer oxygen if necessary. |
EYE CONTACT: | Immediately irrigate with eyewash solution or clean water, holding the eyelids apart for at least 15 minutes. Continue irrigation until medical attention can be obtained. |
SKIN CONTACT: | Remove contaminated clothing. Drench with large quantities of water. Continue to wash the affected area for at least 10 minutes. |
